Array subset seems not work for x+yi array
After FFT, I got an array of x+yi, and need to cut half of the array.
I use "array subset", but seems not work.
Any suggestion? I am using it for a realtime display. Thanks.
(3,643 Views)
SSorry, it works. Made a mistake.
(3,640 Views)
Can you please a screenshot of what you did initially and why it didn't worked and whether if you changed something and it works please post it in detail. Also please mark that post as solution so that it will help others in the future.
Mathan
(3,636 Views)
Index<1.
(3,627 Views)
