Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
3d object control
3d object control
divyata pandit
Member
09-11-2009
01:10 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
My application is to import 3D VRML file in LV 8.5 I tried to load
a .wrl file using load vrml function but i could not see anything in
picture control.3d file which i was trying to load is of size 15 MB.
0
Kudos
Message
1
of 3
(3,173 Views)
Reply
Re: 3d object control
Gak
Active Participant
09-11-2009
01:16 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hi divya,
Can you post your code.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
0
Kudos
Message
2
of 3
(3,170 Views)
Reply
divya s
Member
09-11-2009
01:29 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
here is the vi & 3D file
3D_Load VRML.zip 2909 KB
0
Kudos
Message
3
of 3
(3,164 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
