Array threshold scan
In the attached VI in Labiew 8.5, I wanted to return the x and y-axis value the last time the temp value is above 100 (on the positive side) and the last time that the temp is below -100 (on the negative side).  I am not sure if it will be easier to scan the values from the right side of the graph to the left to return the correct values.  I wanted to return the following points:
positive side: 100.58, 68.077
negative side:-101.05, 43.93
hiNi.
Message 1 of 10
(5,336 Views)
Message 2 of 10
(5,327 Views)
Accepted by hiNI
Here's a quick attempt:
Be aware that property nodes  execute to top bottom, so you should set the active cursor before setting the position. You also only need two points for the reference lines. I currently show the positions as complex numbers for simplicity. Modify as desired.
Message 3 of 10
(5,323 Views)
Christian, Am just curious to know the reason why you are dividing the array value by 1? Is there any functional difference when we do that?
Message 4 of 10
(5,298 Views)
I am not doing that, it was already in the original code. I left it there because I thought the original programmer might need to tune that factor later. 😉
Message 5 of 10
(5,293 Views)
My bad I didn't see the original code 🙂 (I thought its Christian trick Smiley Tongue )
Message 6 of 10
(5,289 Views)
Hello Jeff,
Can you include your code in LV 8.  For some reason, I am not getting the correct "unbundle" data to go to the threshold block.
hiNi
Message 7 of 10
(5,264 Views)
Jeff,
Did you mean to have the unbundle give different sets of arrays?  Because you aren't.  Another danger of using the same name for controls/indicators.
Message 8 of 10
(5,261 Views)
Change the label of the two arrays in the cluster to something unique, e.g. "X" and "Y" to keep things sane. Otherwise, use a plain (not "by name") unbundle.
Message 9 of 10
(5,254 Views)
@crossrulz wrote:
Jeff,
It was a quick-n-dirty created constant from the original graph.  Not the way I normally program.Smiley Wink just to show an alternate approach for a find last crossing index
Message 10 of 10
(5,251 Views)
