Array to Spreadsheet String VI truncating my rows
I'm using Labview 8.0.
In my VI I am feeding the "Array to Spreadsheet String" VI an array of strings that are in the following format.
7/09/2010 7:43:23.27472 95.284953
7/09/2010 7:43:23.27572 95.284953
7/09/2010 7:43:23.27672 95.284953
7/09/2010 7:43:23.27772 95.284953
The first entry is the data, then time, then data.
The problem I am having is that when I pass this array of strings through the "Array to Spreadsheet String" VI it cuts off the entries and I get the following:
07/
07/
07/
07/
The format I feed to the VI is <%s> for string. Any help would be great. Thanks!
Message 1 of 15
(6,833 Views)
Hi Emike,
for me this works:
18475i9F8DF441892655E7
Message 2 of 15
(6,828 Views)
Do you have a screen shot of your code? I took the arry that you gave and I can get it to export with no problems.
Tim
GHSP
Message 3 of 15
(6,825 Views)
Here is the screenshot. The GUI is in the upper portion of the screen so you can see what the outputs are.18477iE318314CDAD3B4FF Thanks.
Message 4 of 15
(6,821 Views)
Hi Emike,
again no problem:
18481i6B8368E626B52DD3
Message 5 of 15
(6,813 Views)
18483iDD9BE4E70B5BEA79
Tim
GHSP
Message 6 of 15
(6,797 Views)
I'm still having an issue. I am thinking it might be in the way I am building my array that I pass to the Write to Spreadsheet VI. Here is a screen shot of the code that builds the array.
18485i9F76DAE34F53384C
Message 7 of 15
(6,792 Views)
That function you suggest take a spreadsheet string and converts it to an array. But my data is already in an array form and I need it in a spreadsheet string form. When I tried it, I get terminal source compatibility issues.
Message 8 of 15
(6,786 Views)
You are building a string not an array. You need to replace the concatinate string with a buil array and get a 2D array not a string for this to work properly.
18487iAC66B1AB8EE3A4E2
Tim
GHSP
Message 9 of 15
(6,784 Views)
It is almost working now. I get both the time and the data, but the problem is that the Array to Spreadsheet String function is only letting through three characters from each column.
Message 10 of 15
(6,756 Views)
