Array to .wav sound file
I have an Array of 16-bit Integer data which is acquired with sampling rate of 262144 Samples per second. Can anyone help with how can I convert this signal to its corresponding sound output and save it as a .wav file?
(1,519 Views)
Accepted by linu95k
Did you see that LabVIEW has a set of sound functions ?
The one that you need is the Sound File Write Simple.vi
The input is an Array of waveforms.
You need to convert you're data into that (To, dt, Array of data).
(1,487 Views)
