Array values are not giving default values
I tried tat.But no use dude. Check the file attatched.
Message 11 of 16
(1,280 Views)
You are wrong. That is NOT an empty array constant. It is a '0' array constant. There is difference between the two. Rt-click on it >> Data Operations >> Empty Array is the correct way to go.
However, I m NOT so sure of the exact short-cut menu option, since I dont have LV as of now.
Just try for yourself.
- Partha ( CLD until Oct 2027 🙂 )
Message 12 of 16
(1,274 Views)
I didnt find empty array constant anywhr. If possibl say me hw i can get tat. Thanx 4 the awesome replies dude.
Message 13 of 16
(1,268 Views)
Just rt-click on the zero array constant you have already connected & then proceed with the steps I have given in my previous reply.
Message 14 of 16
(1,266 Views)
I tried lik tat. But no use. iam not getting anythng. Any othr solution???????
Message 15 of 16
(1,242 Views)
I got the solution. Thanks 4 d suggestions.
Message 16 of 16
(1,231 Views)
