Array with Fibonacci numbers
I am trying to construct a VI with one numeric input n that builds the array containing n Fibonacci number, beginning with F1.  The Fibonacci number is not defined for 0 or negative numbers.I need to  make sure that the user is not able to enter any number less than one.  And the output display should be a 2D array having a column for the values of "n" and a column for the corresponding Fibonacci number. (i.e., not two 1D arrays).
I know that a fibonacci numbers are the sequence of numbers, denoted by Fn.  Defined by the relation Fn=F(n-2) + F(n-1) with F1 =1 and F2 =1.
The following table shows the values of Fn that i need to obtain for the first few values of n (all inputs are positive values).
n       Fn
1        1
2        1
3        2
4        3
5        5
6        8
7       13
8       21
9       34
10     55
I am not sure where to even start, I'm probably making this harder than it needs to be.  If anyone could help that would be great
Many thanks
Message 1 of 30
(20,535 Views)
i would suggest using n to control a for loop that calculates the Fn numbers. you may need to look up shift registers as well and a few examples. So the loop runs n times calculating the series as it goes.
Hope it helps
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
Message 2 of 30
(20,530 Views)
Hi Calavan,
This sounds like homework! To be clear from the start, nobody here on the forums is going to code this for you, but if you have a go we can give you tips/pointers and help if you've got any specific problems
Firstly I would get to grip with the LabVIEW basics: https://learn.ni.com/learn/article/labview-tutorial
When you've had a look at those tutorials then you'll see the solution to your problem is very easy to implement in LabVIEW.
A couple of hints:
  • for loops
  • numeric VIs or a formula node
-CC
"If anyone needs me, I'll be in the Angry Dome!"
Message 3 of 30
(20,527 Views)
my thoughts exactly, im happy to give pointers and once youve had a good go it constructive critisism. the search tool on this website is very good and so are the examples that ship with labview
Good Luck
Message 4 of 30
(20,523 Views)
right click on your numeric control --> Data Entry --> Remove the checkmark from the Use Default Limits -->  Minimum field, set the value limit (1) and select Coerce.
Changing Data Ranges of Numeric Controls and Indicators
https://www.ni.com/docs/en-US/bundle/labview/page/changing-data-ranges-of-numeric-controls-and-indic...
_____________________________________________________________________
---Please mark a post as a Solution if it solved your problem ---
Message 5 of 30
(20,518 Views)
Oops, I think Xenox has posted in the wrong thread here Smiley Surprised
Message 6 of 30
(20,513 Views)
My post relates to his question:
"...I need to  make sure that the user is not able to enter any number less than one... "
Message 7 of 30
(20,507 Views)
Ah sorry then, my mistake
-CC
Message 8 of 30
(20,504 Views)
You can make this with shift register in a for loop quite easily.
Tip: You can pull down your shift-register node to get the value from the last round of FOR/WHILE-loop
Tip 2: You can also initialize pulled-down shift register node from last round for FOR-loops loop 0
This should help you enough to make your code.
Message 9 of 30
(20,496 Views)
Thanks, I'll be posting my code soon
Message 10 of 30
(20,482 Views)
