Setting up triggering
Hello, I have a 9184 Cdaq chassis, and I am trying to synchronize an AI (Ni-9205) task with an DI (Ni-9403) Task.
My goal is to use my AI to trigger my DI. But I have run into quite a bit of heart ache when trying to do this.
I will attach images below of how i thought i was supposed to set up the trigger. Any insight would be greatly appreciated.
If i haven't provided sufficient information let me know what else I can add.
(3,871 Views)
If you're going to make us download something (3X), at least make it a VI. If you insist on posting images, at least embed them in the post so we don't have to download them.
1
2
3
(3,852 Views)
The reason i have not attached the VI's is because it is a little larger of a program, and I have a bunch of GOOP stuff going on.
I did not know about embedding the images, I am sorry.
Still new to these forums.
(3,847 Views)
That's OK. (I'm not that into DAQ, so won't be doing you a favor answering the question.)
(3,842 Views)
But some of us are into DAQ, and I, for one, won't bother looking at pictures of code when the VIs, themselves, are available ...  With a VI, we can inspect the code closely, looking at all the cases of a Case structure, test the code, edit the code, clean up the code, see what version of LabVIEW you are using, etc.
Bob Schor
(3,837 Views)
The project file is too large to attach. I can attach attach the process vi, that's where my Daq stuff is occurring. I will attach the VI for the front panel as well just in case you were hoping to see that as well.
(3,835 Views)
