Array
I have numbers in the block diagram. 0 2 4 6 are the x coordinates, while 1 3 5 7 are the y coordinates. When I save the x And y coordinates are on the same row, but I want the X coordinates in the first row and the y coordinates in the second row. Is there a way to solve this problem???
(3,533 Views)
Accepted by Mark87
You need to make your data a 2D array
Omar
(3,517 Views)
Sorry Omar, can you post the jpeg image. I haven't the last version of LabVIEW.
Thanks for your reply.
(3,455 Views)
Hi Mark,
in your VI you create a 1D array of data - and then you wonder why they are saved as one row? Really?
You have to put those values in a 2D array. To do so create 1D arrays for both x and y values and then build a 2D array from those two 1D arrays…
(3,448 Views)
Here is the screenshot. But thank Omar_II, if you mean that his was useful.
(3,432 Views)
Or you could simply do a reshape&transpose.
(3,421 Views)
