Arrays greater than 0 and taking only the elements that doesn't contain that
Do you need to keep track of these errors?  The other alternative is to never save them to begin with.
Message 11 of 21
(1,195 Views)
if there are other alternatives. i would love to hear it or see it.
i think its for better interest that we keep track of it.
but ultimately, i want to create an excel file and that is the reason why i want to take those ZEROS off.
I don't want to have a too wide of a scale on the graph.i want the graph to look something like this, but on excel.
Krispiekream
Message 12 of 21
(1,191 Views)
Matthew said
Be careful with this approach.  Any x value less than 0.5 will be dropped in this solution.
Quite right, Matthew. That was an assumption on my part that I did not state as I was just looking at the data he had.
To poster: Do you have any control over the zeros being generated in the first place? If you don't have to deal with them...
Message 13 of 21
(1,163 Views)
If you have access to where the programmer sets it to 0, I would set it to a negative number at bare minimum.  This is a completely impossible value, assuming x is time.  If you're parsing them out in your Excel file, you're not traking them anyway, so you can never save them.  Again, if you have access to where the programmer is setting it to 0, just don't save the data.
Message 14 of 21
(1,158 Views)
smercurio_fc, can you attach the vi file you used to create the images. i am having a hard time finding the array replace subset on 8.0
Krispiekream
Message 15 of 21
(1,147 Views)
Don't quite understand your statement since I wasn't using the Replace Subset function in the example I showed you. You may want to change your palette setting to display the function names:
You can do this from Tools->Options. Change to the "Controls/Functions Palettes" category and select "Category (Icons and Text)" from the "Format" menu. You can see the Replace Subset there on the first row.
For what it's worth, I've attached the example VI.
Message Edited by smercurio_fc on 11-06-2007 11:26 AM
Message 16 of 21
(1,133 Views)
i think i did the same thing. but i didnt get the output like your example. did i do something wrong?
Krispiekream
Message 17 of 21
(1,131 Views)
thanks, that helped!
Krispiekream
Message 18 of 21
(1,130 Views)
new problem, can anyone suggest a solution?
to start the program, i have created an excel file with a header looking like this
image 1.
i am not too familiar with creating excel file. so someone suggested that i use ".XLS"
and write/replace it in a spreadsheet.
on the left is method (image 2)
but I know that method 2 is the correct way of doing this.
i need to do 1 thing.
have the same header i start with. add to the files the data(s)
but i have to keep the function that doesn't take the "ZEROS"
I hope someone can suggest a solution.
thanks
Krispiekream
Message 19 of 21
(1,112 Views)
For a new question, you should really start a new thread, that way, if someone else has a similar question later, they are more likely to find your question (and the solution) when they search, so it avoids repeated questions.
To get familiar with using excel, check out the examples in the example finder and see if they get you started.
Jeff
Using Labview 7 Express
Message 20 of 21
(1,103 Views)
