Arrays in Pda Modul
Hi!
If modulate pda Unsupported arrays in the Front Panel.
I can use arrays in the construction of a program?
The block diagram will work well?
Thanks for your aid.
G.B.
(3,010 Views)
Not sure this is your question, but here goes:
The fact that arrays don't display on screen does not mean that you can't use arrays. So use them, except for display purposes. That said, you can expect strange behaviour if you create  very complicated  (cluster) data types.
(3,013 Views)
Thanks Aart-Jan. I imagined this but she was not safe. G.B.
(3,003 Views)
