Path in Pocket pc
Hi!
Robot Sad
I have a problem.  I cannot read a file working with I modulate of pda.
I want to know how the path of a file is written. The file is kept in Pocket PC, in My Documents and their name is 'Area.txt'.
The figure shows pda.
Thanks.
Greta
(3,628 Views)
that would be the following path: My Documents\Area.txt
I believe the path may be case sensitive.
(3,624 Views)
Hi Aart-Jan!
This path out of order. I cannot open a file with modulate of pda.
You know because it can be?
Greta
(3,620 Views)
the attached vi works on my pda and illustrates the use of the path variable as well as reading and writing text files. Examining the code should help you solve your problem. Good luck!
(3,619 Views)
Thank you very much by the aid. I have executed the program and I have been able to read the file. Again, thank you very much. Greta
(3,606 Views)
