Asking for Guidement about simulation in LabView
I am also trying to find a way how to connect with the one I built in LabView. Can you please give help me? Thank you so much
Message 11 of 14
(410 Views)
All you have to do is zip the folder that your code is in and drag it to the box blow that says "drag and drop here or browse files to attach"
Tim
GHSP
Message 12 of 14
(375 Views)
I have draged the ZIP folder here, thank you for your help.
Message 13 of 14
(276 Views)
My name is Ichrak Zidi, and I am currently a master's student at the University of Applied Sciences Berlin (HTW Berlin). As part of my master's thesis, which focuses on enhancing the expressiveness regarding measurement uncertainties of chained measurement variables, I require the use of LabView.
I am writing to ask for a guiding whether it is possible to obtain to obtain more help and tips.
Quick Explanation about the task:
I have already build a test bench, a calibrator fluke 5502A, and a current sensor (DS600ID) and Dewetron. I simulated in LabView an I have got this VI file completed and finished. I want to do a measurement of Voltage and Current with a calibration routine  then I get a graphically output as rising rectangular function in Dewetron.
The only thing now is that the calibrator has a range maximum of 20A for the current and the sensor that i want to test its max is 1000A. I did 5 windings in the sensor before which its max 100A in my test bench so that the calibrator will meaure from 0A then 5A until 100A and he won't know that, so the measurement will be every 5A. That's why also in the VI file i put a constant 5 in the range block of the fluke in labview. But this is only able for sensors of 100A max. What i want is that the current measurement shown in Dewetron from 0A-1A-2A-...1000A so the step size will be 1A.
How can i do that, how can i make the calibrator measure until 1000A with step size of 1A, what should i change in my VI file considering all these conditions and without causing any errors or defaults by the calibrator or the sensor itself? How can I simulate it?
I would greatly appreciate your support and a positive response to this request.
Thank you very much in advance for your assistance.
Ichrak
Message 14 of 14
(262 Views)
