Assign a value to the radio button selection
Hello dear all,
I have several radio buttons (20) (but I put only 2 here for simplicity)
I want when I select or click on a selection (for example on concentration) that its value is 1 and Entertainment value is 0.
Then I have to save it on a text file as follows:
Concentration: 1
Entertainment: 0
How do I do it please?
Message 1 of 11
(2,286 Views)
Use the radiobutton to index into an array of values.
If you want to format the value as integer instead of the element string, just convert to e.g. U32:
Message 2 of 11
(2,263 Views)
Thank you for your answer @altenbach.
I think you have understood what I want.
Let's start with a single radio button.
When I click on Concentration its value =1 and the other one (enterntainment) that I did not click its value =0
Ps: I am still on the same radio button.
Below the file.txt that I have by clicking on concentration then on save and what I want to have.
I do not know is it clear?
I have thought of several scenarios but I do not know how to do it.
Message 3 of 11
(2,221 Views)
Try this:
Message 4 of 11
(2,192 Views)
And if you want all states, here's one possibility:
(see below)
Message 5 of 11
(2,188 Views)
Accepted by Ngouda
It is really not clear what you want, because only one selection can be true at any time, but if you want a "1" for the selected item and "0" for all others in that radio-control, here's one possibility:
Message 6 of 11
(2,179 Views)
@Ngouda you should give a kudo and accept a solution. It's also a way of showing gratitude besides saying "thank you".
Message 7 of 11
(2,164 Views)
Dear @altenbach
Thank you very much, it works as I wanted it to.
Good evening to you
Thank you.
Message 8 of 11
(2,155 Views)
@GRCK
I don't understand the meaning of your answer.
I think it's obvious that I was going to answer him as soon as I could and thank him and accept it as a solution, because he took his time to answer me and help me for free with a lot of kindness.
Thanks again @altenbach
Message 9 of 11
(2,151 Views)
Thanks for answering! Now you understand the meaning of my answer. 😂
By the way, we are twins (same profile picture) Hahah.
Message 10 of 11
(2,143 Views)
