Assign physical channel in elvis
Dear all:
  I am a user of LabVIEW 2010. Recently, I have downloaded the lockin start up kit. I want to use ELVIS for the signal input. I want to input the data signal and reference signal using scope 0 and 1. But in the front panel of the demo lockin program, I only can assign 1 scope for input. I have see the back panel of the program, the signal from the DAQ is 2d array. Therefore, all scope should be assigned. How I can assign the input in front panel?
(3,048 Views)
(3,047 Views)
Help!! Can anyone tell me that scope 0 and scope 1 of elvis support to be assigned in 1 DAOmx physical channel?
(3,018 Views)
I'm having trouble following your hardware setup. Could you explain what hardware and connecitons your are using?
(2,991 Views)
I have solved the problem, thank!
(2,975 Views)
