Close vi when it loses focus
Hi Guys!
I have a popup VI that I need to close when it loses focus, for example if the user clicks back on the mother program.  I found an old example using the "is frontmost" property node, but this node won't give the feedback needed.
Have any ideas?
Thanks!
Christopher
(3,447 Views)
The popup itself can't be modal because that will prevent it from losing focus.
aputman
(3,437 Views)
Use an Event Structure.  The event you are looking for is Application->VI Deactivation.
(3,432 Views)
Is that a 2013 event?  I don't see that in 2012.
aputman
(3,426 Views)
Accepted by topic author Pickering
Most "Pop-up" Dialogs are Modal.  In order to get what you are seeking the pop-up must be "Floating"
Here is a quick example that may work close to what I thing you want---it may need some tweaks
(3,425 Views)
Works like a charm, thank you!
(3,379 Views)
