Close vi when it loses focus
Hi Guys!
I have a popup VI that I need to close when it loses focus, for example if the user clicks back on the mother program.  I found an old example using the "is frontmost" property node, but this node won't give the feedback needed.
Have any ideas?
Thanks!
Christopher
(3,467 Views)
The popup itself can't be modal because that will prevent it from losing focus.
aputman
(3,457 Views)
Use an Event Structure.  The event you are looking for is Application->VI Deactivation.
(3,452 Views)
Is that a 2013 event?  I don't see that in 2012.
aputman
(3,446 Views)
Accepted by Pickering
Most "Pop-up" Dialogs are Modal.  In order to get what you are seeking the pop-up must be "Floating"
Here is a quick example that may work close to what I thing you want---it may need some tweaks
(3,445 Views)
Works like a charm, thank you!
(3,399 Views)
