Assign signals to channel - DAQMX
Hello everyone,
I want to create a task with 4 signals on 4 different channels. Simply wiring the singalarray to the the write.vi for N-Channels_N_Samples assigns the signals to random channels.
Every time I start the VI the signals are applied to a different channel and not as they are positioned in the array.
Is there a way to assign channel1 to signal1?
(2,572 Views)
They should be in the order that you added your channels to the task.  Could you share some code so we can see if we can find your issue?
(2,568 Views)
Accepted by s.h._tech
Hi sh,
The signals are assigned to the channels in the very same order as the channels are defined within the DAQmx task.
All you need to do is to define the DAQmx task with your channels in the correct order…
(2,567 Views)
When selecting multiple channels (AO1:3) in the control they correspond in this order?
  • AO1 - Signal1 (position 0 in the array)
  • AO2 - Signal2 (pos 1 in array)
(2,561 Views)
That is correct.
(2,546 Views)
