02-20-2024 11:03 AM
@siddhu01 wrote:
Hi Alten
i have updated the image above as u can see the string array Rte_SchM_rt_min has unsigned long [6] which mean each index have seperate values
for example [0] = 0 or any values so i need to implement [0] has 0 values and need to assigned with string array Rte_SchM_rt_MIN
Finally it should be like Rte_scHm_rt_min[0] =0
this method i need to implement in labview kindly support on this .
This is all still complete gibberish. Maybe you could post your question in your own language and we can use Google translate to read it, hopefully more clearly.
An "index" is just an offset into the array, while the "values" is what we find at that offset. Indices are unique. Your image shows "unsigned long", but then you talk about "string" arrays. Makes no sense!
If the problem is inexperience with LabVIEW, how would you implement "it" in any other programming language?
02-21-2024 03:31 AM
Something like this?
02-27-2024 04:15 AM
hi altenbech
the issue has been resolved thank you for the Kind words 🙂 really i am inexperience in LabVIEW but u cannot justify as per your wish anyways thanks for the support
