Assistance Needed: Averaging N Amount of Waveforms
Firstly, I apologies for re-posting this subject, but I haven't had the help I needed the last time I asked, probably because I didn't state clearly what my problem was. So here goes....
What I need is for some genius here to show me how to average N amount of waveforms. I am measuring fluctuations in current over a specific time window (this depends on the amount of samples and of course the sampling rate I use).
Currently, I'm recording N amount of waveforms (time series), but what I want to do is to only record one averaged waveform, e.g. n1+n2+n3/N (N=3).
I gave this a go using a for loop but it didn't give me the results I want (I know what is wrong with it but don't know how to produce the averaged waveform).
In summary to be as clear as I can be,
1) I'm recording N waveforms from the DAQ Assistant
2) I want to collect these in a queue and then take the average of the N waveforms
3) Record the averaged waveform to my Write Measurement Function.
Attached are 2 LabView versions of my project.
I'd really like to have this up and running this week if possible and would really appreciate the help in modifying my vi.
Many thanks for reading!
AT 12.
Message 1 of 40
(3,965 Views)
I haven't messed with averaging waveforms much, but does this work?
Message 2 of 40
(3,955 Views)
Huge thanks for the rapid response! I will try it out and come back to you asap. Smiley Happy
Message 3 of 40
(3,949 Views)
Any chance you could upload the vi, so I can figure out what's what?
Message 4 of 40
(3,946 Views)
I'll just tell you; if you find it yourself in the palettes (use the "search" feature which the palette provides) you will be more likely to remember everything and where they are. There is a for loop, a numeric control, convert from dynamic data, an add function, and a shift register. Configure the convert from dynamic data to be a scalar waveform (you do this by double clicking on the node). The shift register you get by right clicking the loop and selecting add shift register. The add function is just a standard add function, and it will add the error terminals to itself when you wire up a waveform. Let me know if you can't find anything specifically.
Message 5 of 40
(3,943 Views)
I'm not sure if I've done it right - a screenshot is uploaded and a modified vi - I think this is what I had done.
If I put, 25 say, in the numeric control it just cuts each waveform saved to the first 25 points. It doesn't average them, as in my recorded data are still 25 waveforms instead of 1!
Any ideas? My hunch is a queue would be required.
AT12.
Message 6 of 40
(3,935 Views)
Any other ideas anyone?
Message 7 of 40
(3,909 Views)
Is this really a hard thing to achieve on LabView? Considering you could do it with a calculator (if you had the time) I'd have thought it could have been done?
Is it worth my time and effort to continue with this?
Message 8 of 40
(3,894 Views)
I think this is what you are going for.
You should be dividing by how many acquisitions you have made.  The FOR loop isn't needed.  Your shift registers should be on your while loop.  On the first iteration, initialize to the first set of acquired data.
GCentral
Message 9 of 40
(3,892 Views)
Many thanks for what you've done - greatly appreciated.
There is still a problem though....
It doesn't give me any averaged I(t) data, and it gives me multiple sets of PSD data at the end?
Am I doing something silly? I've ran it with 0 in the shift register constant and with numbers in it, to the same effect - no I(t) data.
Thanks very much once again,
AT12.
Message 10 of 40
(3,884 Views)
