Asynchronous AI/AO ... totally frustrated!
Hi Berns-
Actually, NI-DAQmx is the first and currently only NI-DAQ driver that has multi-threading capabilities.  The problems you are seeing are a result of improper use- please keep in mind that the example you are working with was intended for use by two different analog output cards (as mentioned in the help file for that example), so extensive modifications will be necessary and expected to work with your single-card solution.  Please see this thread for further discussion.
Thanks-
Tom W
Message 11 of 12
(655 Views)
Hello:
Sorry buy projects on the deadline and I though the express and the examples would hack it! Anyway is there anyway for a fix up for a two P-controller analog output? Would it be possible to generate DAQmx from Express?
Berns B.
Bernardino Jerez Buenaobra
Senior Test and Systems Development Engineer
Test and Systems Development Group
Integrated Microelectronics Inc.- Philippines
Telephone:+632772-4941-43
Fax/Data: +632772-4944
URL: http://www.imiphil.com/our_location.html
email: Bernardino.Buenaobra@ph.global-imi.com
Message 12 of 12
(651 Views)
