Asynchronous Call - collect OR forget?
Hi all,
I want to optimize one of my LabView procedures. Let's say that I've got 2 VIs that return the same values, but use differend data sources. I'd like to launch both of them and simply collect the result from the faster one.
I figured I could do this by running both VIs asynchronously and polling a global variable, but I was hoping that there is a better solution.
If I "Wait on asynchronous call" for both VI, I'll wait for the slowest one to finish. Is there a way to check if VI has finished its job without running into "wait on asynchronous call"?
Thanks in advance!
Tomasz
(3,629 Views)
Accepted by McTOM
Hi Tomasz,
run both subVIs in parallel and let them write their results to the same notifier or queue.
In your MainVI you just use the first value coming from the notifier/queue by setting it's timeout to -1…
(3,623 Views)
In this case, I would probably go with the notifier.  You could possibly also go with a User Event.
(3,617 Views)
It is a better idea than polling a global variable, but then again, after reading the queue I'll probably destroy it right away, invalidating its reference used by the slower VI. It should check if it's still valid then.
I was hoping for something else, but this will do as well. Thanks!
(3,615 Views)
Hi Tomasz,
each reference of the notifier/queue can be closed without destroying the notifier/queue! Infact this is standard behaviour as written in the help
What "something else" are you looking for?
(3,610 Views)
Indeed you are right! My bad! 🙂
Thanks again!
(3,606 Views)
