Asyncrounous VI call
I'm having issues launching my Load PDF.vi as my target VI using a Start Asynchronous Call. I'm Attaching my target VI and event case block diagram scrnshots.
When the event case is run, the PDF file is loaded and then closed very fast, tried different VI properties on Window Appareance, etc with no success.
Any thoughts..Thanks!
R
(3,075 Views)
Have you tried not closing the reference?
(3,051 Views)
Yes, tried that, still the VI wont pop up.
(3,022 Views)
Got it now, had to add a loop to my target VI wit a stop button to keep it from closing when called.
R
(2,997 Views)
