is there any good example for large DAQ project
Hello
I worked on a project which includes several sub VI, These sub VI are different DAQ processes (from Visa and NI daq)
They all use Producer consumer structure
I have a main VI which is a user interface. On the FP of main VI, I only prefer several important control buttons, such as instrument configuration(eg.  write set point, correct port No. etc), acquire, exit.
I plan to use refnum to get data from sub VI  showing in waveform chart . All control button will be also refnum controlling sub VI.
I am not sure if there is some good example for this kind of project. I pretty appreciate your help.
(3,457 Views)
Who has any advice??
(3,418 Views)
This White Paper has some good templates and sample projects.
https://www.ni.com/en/support/documentation/supplemental/12/labview-templates-and-sample-projects.ht...
Is this what you are looking for?
Kind Regards,
James O'Neill - Applications Engineer - National Instruments
(3,413 Views)
Yes
But where is the project file to download?
I cannot find it.
I only can see the document
(3,401 Views)
(3,398 Views)
so this one can be only used in labview 2012, right?
(3,395 Views)
Dragon-long,
LabVIEW 2012 shipped with a lot of great examples. The previously linked document is a walkthrough for a project that did ship with 2012. Do you have access to LabVIEW 2012? There are a lot of great shipping example projects in this version.
The link that you posted is not related to the shipping examples in 2012 that were mentioned.
I'm not having a lot of luck finding community examples for DAQ projects, but I urge you to do some further searching at www.ni.com/examples/ to see if you find something that will work for you.
Joel C
(3,368 Views)
