Audio signal to PDM signal converter
Hi all,
I need to generate PDM signal of 2.048MHz frequency from a audio file(.wav file) of max16kHz frequency. I am able to read audio file by using from 'sound file read sample' API and also I am able to convert it into PDM signal but generated PDM signal is have only 7984.33 Hz frequency. Hence, help to fine PDM signal of 2.048MHz frequency from given audio signal.
PDM signal creation logic I got from below link
https://forums.ni.com/t5/Example-Programs/Pulse-Density-Modulation-PDM/ta-p/3532976
thanks and regards
Gyali2015
Message 1 of 1
(4,359 Views)
