Image morphology: using erosion after color selection
I need to identify a green circle and so far I've used the IMAQ ColorThreshold vi for colour recognition. Now I want to get rid of the noise with erosion and dilation but when I wire the vi, the image just goes black. What could be the problem? Also, I tried to wire the image src input to the original image then the image is just plain white. I link the picture
(3,067 Views)
A mistake I fall for every time is that Boolean operations return 0's and 1's. So you have to format the image as "binary" to see something.
(3,037 Views)
But why would this be a boolean operation? It's an image type no?
(3,021 Views)
A threshold returns 0's (above threshold) and 1's (below threshold). So the result is Boolean.
You don't need to change the image type, you need to change the color scheme.
A 0\1 still fits in a u8 image, but you won't see anything in the default color scheme. You'll need the Boolean color scheme, that has black as 0, and red as >0.
(3,012 Views)
I looked into what you said. But what I don't understand is that with both new image I set the image type to grayscale(U8) and I checked with the image info the output of the threshold and it's also grayscale. So why are they not compatible? I don't see that I would use the normal color scale anywhere, it should be boolean. Where am I wrong?
(2,986 Views)
U8 is just the data type to hold the data. A Boolean needs an U8 (at least), as there is no Boolean data type image.
The term " Grayscale(u8)" is just confusing. U8 and grayscale are mutually exclusive. You'll need an U8 image type, but a Boolean palette. A grayscale color scale will simply display 0 as black, and 1 as nearly black. Alternatively, multiply the image with 255. That will make the 1's 255's, and that will show up as white.
(2,982 Views)
