Auto cRIO connection
Hello!
Can somebody help me with this: I made a project in which I added a cRIO and a touch panel. The communication between the two is accomblished by shared variables. The main-core code is placed in the cRIO vi, thus what I want to do is making cRIO vi running when I open the touch panel exe.
Hoping I gave you understood.
Thanks in advance
(3,202 Views)
I am not sure how you can start an RT VI in cRIO from TPC. Another workaround is to place your the cRIO VI as a startup VI in RT. Once cRIO powers up it will start running this VI.  Let this RT VI poll on a boolean shared variable to decide whether to execute the "Actual" part of the code. This shared variable can be set from the TPC.
"A VI inside a Class is worth hundreds in the bush"
യവന്‍ പുലിയാണു കേട്ടാ!!!
(3,198 Views)
Thank you very much. I will try
Best Regards
(3,194 Views)
