OS X breaks Labview
The newest version of OS X breaks Labview.
The ".vi" extension has already been used ?
Message 1 of 8
(4,231 Views)
What versions of OS X and LV are you using?  What happens to cause you to think that "OS X breaks Labview"?
I am running OS X 10.5.6 on a Quad core Mac Pro with LV 8.5 and 8.6 and have not seen any problems.
Lynn
Message 2 of 8
(4,221 Views)
Also, searching fileinfo.com for the vi extension only returns LabVIEW as the associated application on Mac, Windows and Linux.
Lynn
Message 3 of 8
(4,217 Views)
I upgraded a Intel MacBook to 10.5.6  after several LV files lost their LV icons
and  reverted to RTF.  A Apple store tech disabled QuickLook via a shell script
at the problem abated. Unix has a text editor called "Vi" that may write files that
are being confused with Labview files.
Message 4 of 8
(4,208 Views)
I do not see that effect with Quick Look.  It just shows LV icons.  I have vim  which is Vi IMproved, but a quick scan of the vi man page does not give any hint that the .vi file extension is associated with that program.
Lynn
Message 5 of 8
(4,199 Views)
do you have a tel # that I can call you.
Message 6 of 8
(4,192 Views)
I will be away from my office the rest of the day.  I should have some time tomorrow.
Lynn
Message 7 of 8
(4,181 Views)
Look at our web site for the last 5 digits of the number: http://www.instrumentationlab.muohio.edu/   The staff link will take you to the right part of the page.
The area code is 513 and the exchange is 529.  Note that the "9" is part of thenumber listed on the web page.
Lynn
Message 8 of 8
(4,159 Views)
