Auto open spreadsheet at end of Vi
Hello. I would like to know if it is possible for the .csv to open immediately after Vi has finished? The filename for the spreadsheet is already decided prior to test. It will be running on PC using Windows 7, if that matters. Thanks much for your time.
(3,770 Views)
Accepted by topic author ceilingwalker
For others who see this thread, the password for his VI is "2015"
Do you want to just open the file in its default program? If so, add this in at the very end of your code (after the loop has finished, this should run):
The path input should be the path for the file to be opened. This essentially just uses the command line to open the file, so Windows decides how to open it.
Cheers
(3,761 Views)
One simple way to do it would be to call excel with the command line, something like this: excel.png
(3,754 Views)
Use the System Exec to call the file.  Windows will open it with whatever it thinks is the default application for the file type.
(3,738 Views)
PERFECT! That's exactly what I was looking for. Thank you guy's for much for your wonderful support. Smiley Very Happy
Sorry for not posting the password. Yet another stupid mistake. Thanks again.
(3,712 Views)
