Auto pressing a button
Hello everyone. Is there any setting in Front Panel, to auto pressing a button in every "x" seconds i can define it to. I made a program and i have to press a button every 15. seconds, so i can be away from keyboard and still make measurements.
Thanks in advance
Oesen
Best regards
Oesen
Message 1 of 12
(4,865 Views)
You can even make measurements every 15 seconds even without involving any buttons.
How to do it depends on the program, so please show us your code. Thanks.
Message 2 of 12
(4,864 Views)
Thanks for the answer 🙂
Best regards
Oesen
Message 3 of 12
(4,853 Views)
You could assign a timeout to the measurement case.
(You are building the data array way too complicated. All you need is a "build array". No need to take the size, then use "insert into array". You also seem to have race conditions, because the "elapsed time is measured first, potentially way before the measurement is taken.)
Message 4 of 12
(4,824 Views)
Hi Oesen
Did you have a chance to look a altenbach's recommendations? He is right in that the timeout case would be the right thing for you to use.
I have modified you VI to include this timeout in the top loop. Let me know if this works for you.
Best Regards
Anders Rohde
National Instruments Denmark
Message 5 of 12
(4,794 Views)
Can you upload it as a 2010 version please 🙂
Best regards
Oesen
Message 6 of 12
(4,787 Views)
Accepted by topic author Oesen
Here you go, please let me know if this solves you problem
Message 7 of 12
(4,775 Views)
Thanks !.. That solved my problem, but is there any way to define the timeout time (15s) in the Front Panel instead of the Block diagram ?
Best regards
Oesen
Message 8 of 12
(4,764 Views)
Turn the constant of 15,000 into a control.
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
Message 9 of 12
(4,762 Views)
Thanks for the help
Best regards
Oesen
Message 10 of 12
(4,760 Views)
