Auto pressing a button
You are welcome Oesen,
Have a nice day
Best Regards
Anders Rohde
National Instruments Denmark
Message 11 of 12
(583 Views)
I don't understant why you need to duplicate the entire case, adding local variables!
All you need to do is add the timeout event to the button case so the same event reacts to both.
I also modified your convoluted (array size, insert into array). A simple "built array" is sufficient.
(I have the feeling that this project is nowhere complete. Seems rather convoluted and dysfunctional.)
Here's a very quick edit. I only adddressed three points: (1) combine events, (2) clean up array building, (3) change timeout to a control..
(You still need to deal with the race conditions, etc.)
Message 12 of 12
(572 Views)
