Auto size of table
is there a property to automatically change the size of the columns in a table?
As you can see in the attached vi there is text in column 1 which is not completely visible.
Can this be resized with a property?
Thx for the help
Message 1 of 35
(8,269 Views)
Use the Cell Size property for that particular column.
- Partha ( CLD until Oct 2027 🙂 )
Message 2 of 35
(8,253 Views)
To my knowledge, there is no automatic solution to adapt the column width to the cell contents.
You can change programmatically the column width using the active cell/cell size property node.
Finding the right width is another story, since it depends on the font used. There is a graphic function in the Picture palette that get the size of a string : Get Text Rect. You could use it in combination with the cell size PN, assuming that you don't use fancy text attributes.
Chilly Charly    (aka CC)
Message 3 of 35
(8,252 Views)
That was fun ! Hope somebody will use it !..
Message Edité par chilly charly le 10-23-2007 02:05 PM
Message 4 of 35
(8,238 Views)
Hi chilly charly,
this is what i am looking for. Perfect work.
What do i have to change so that there is a reference as input? I want to use this via as an subvi but i only have the reference to the table and not the tabel itself.
Thx again.
Message 5 of 35
(8,232 Views)
OK. Here are the modifications. BTW, it was not necessary to wire the For loop N input. Rube Golberd code ?
Enjoy.
Message Edité par chilly charly le 10-23-2007 02:36 PM
Message 6 of 35
(8,231 Views)
Works great.
Thank you very much for this VI.
Message 7 of 35
(8,216 Views)
CC,
Is the Active Cell/Ccell Size property available only from LV 8.0 upwards? I didnt fid it in 7.1. Smiley Sad
Message 8 of 35
(8,185 Views)
parthabe a écrit: Is the Active Cell/Ccell Size property available only from LV 8.0 upwards? I didnt fid it in 7.1.
Both properties were already available in LV 6. Get new glasses ! :D:D:D
Message 9 of 35
(8,183 Views)
Hi CC,
is the cellfont property something that got introduced after 8.x? I can't find it in 7.0... and if it was available in 7.1 it would solve the problem here.
Jeff
Using Labview 7 Express
Message 10 of 35
(8,174 Views)
