Auto-wire bug when dragging/dropping?
Hi everyone
I just found out that if I have this diagram:
and drag/drop the "equals" into the case structure, the auto-wire function will create a new input tunnel to connect the constant there. The shift register will then be void:
I think it should be normal behaviour the leave the shift register wiring as it is.
Is this a known issue?
Greetings!
Message 1 of 13
(4,660 Views)
I seem to remember some wizard speaking about similar issues.
But I am limited in what I can say.
Ben
Message 2 of 13
(4,654 Views)
What version of LV are you using?
In LV 2016, if I drag the equal function inside the case structure, it disconnects and breaks the line. And yes, I do have auto-wire enabled.
Former Certified LabVIEW Developer (CLD)
Message 3 of 13
(4,624 Views)
Not breaking a wire when dragging a function across boundaries is a feature added to one of the more recent versions of LabVIEW.  Either 2017 or 2018.
Message 4 of 13
(4,621 Views)
@BrotherTom wrote:
Hi everyone
Greetings!
I found the other place where I saw this issue and there was not a good demo of that problem so a CAR was not generated for it.
I flagged a moderator to get an AE to look at this because I was able to duplicate that VI and saw the same bug.
Ben
Message 5 of 13
(4,614 Views)
I really don't care for auto-anything in LabVIEW.  It never seems to auto-whatever the way I expect it to.
Bill
CLD
(Mid-Level minion.)
Message 6 of 13
(4,609 Views)
@BrotherTom wrote:
Hi everyone
This is a known issue being tracked by CAR 718913
Message 7 of 13
(4,596 Views)
Agreed on the auto-things not behaving as desired. I've been adding this collection of keys to labview.ini to try maintain a less automatic and much snappier development environment. Info on each key can be found in this github gist.
LiveDrag=False
LiveSelection=False
DragAutoWire=False
SmarterAutomaticTunnelCreation=False
AutomaticShiftRegisterCreation=False
Certified LabVIEW Architect
Unless otherwise stated, all code snippets and examples provided
by me are "as is", and are free to use and modify without attribution.
Message 8 of 13
(4,572 Views)
Hi folks
Sorry for replying so late!
Indeed it's a pretty new feature. I use LabVIEW 2017 and cannot remember this feature in older versions.
Good thing that a CAR has already been registered. I haven't found anything of it, neither in the web nor in the forums.
Keep up the good work!
Thomas
Message 9 of 13
(4,541 Views)
I hate the 'Maintain Wire Connections' bug (NO!! IT'S NOT A FEATURE, IT'S A BUG!!).  I wish I could turn it off.  Even in those cases where it would be handy, I don't use it* because it tends to rearrange wires idiotically.
* I copy then delete instead of moving.
Message 10 of 13
(4,524 Views)
