AutoConfig To Start
I have a compleate programm but i Wuold open in automatic a Config File, load a path and one device, when the EXE is Started. This is the first Process, exist a solution?
(4,823 Views)
can you describe much better?
Is your problem is while running exe, if so is your program works fine in Development Environment?
(4,815 Views)
Hi Andrea,
exist a solution?
Yes, of course!
You need to load your config file right after starting the EXE. Then parse it's content and do anything you like to do!
General hint: When you want your VI/EXE do something in a certain order you need to program your VI/EXE to do the needed steps in this certain order…
(4,814 Views)
I search to explain the problem
First -> read a config file txt
First Row -> Device name (example DEV1)
Second Row-> path of File -> current VI path + File Name
Save this info and send to Main.VI and load the file and the Device.
Second-> Run the main programm
(4,797 Views)
Accepted by andreabello
have you tried something to do this action?
if yes share the tried code.
if no try to read text file (config file)
https://decibel.ni.com/content/docs/DOC-13937
Once after reading parse your Text which you read from config file (Device name and path File using String Functions)
You can make this as a sub VI.
The output of this VI can be given to your Main VI to do the action.
(4,788 Views)
