Automatic measurement
Hello everyone, I hope to fnd a solution here.
I'm planning a VI wich make an automatic measurement with instruments connected with computer through GPIB.
The instrument are:
-Oscilloscope (HP 54645A)
-Wafeform Generator (Agilent 33250A)
-Data Acquisition (34970A)
I have two big problems I ask you a help.
1) To have two different Graph for the two channel of Oscilloscope I put a "Flat sequence Structure" but if one of channel is not connect the VI give me error. I wish that it read the channel connect and not read the channel not connect
2)With Data acquisition I've planned that it make a series of measurement of temperature with regular intervals of time. I wish find a way to export the results in a file excel which in columns there are measurement that it made.
Thank to everyone who will respond
(3,692 Views)
Hi Enrico,
1)
- In your VI you don't use the error cluster that much. Use them always and as much as possible!
- When you know which channels are connected you should program an algorithm to just measure the connected ones.
- When you don't know which ones are connected you should do some error handling in your VI!
2)
Write your data into a spreadsheet file - there are several functions/VIs allowing you this easily…
For "regular" time intervals it's kind of overkill to use a TimedWhileLoop in your application: you are talking to an external device so a normal While loop with a standard wait function inside is sufficient. In your special case a FOR loop would be more appropriate as you limit the number of readings…
(3,678 Views)
GerdW thank you very much for your answer and your help.
With your advices I changed little bit my project, and I've resolved the second problem but I didn't understand how resolve the first.
I have tried other way to project the oscilloscope but I can't resolve my problem: if I don't attack one channel to oscilloscope the VI gives me error in the error cluster and doesn't show anything in the block diagram.
If you (or anyone else) have a little time to see the attached for say me what I wrong, I'll be appreciative Smiley Wink
I put the all project (L_primo progetto.vi) and the part of project where I have the problem (HP54645A.vi)
(3,613 Views)
