knob loop
How do I prevent a knob ring cell from rolling over when using the incrimentors? In my picture I would like to be able to use the incriment button, but if I incriment from the top, or decrement from the bottom have nothing happen. To be clear I don't want to be able to loop directly from 100 ns to 10 ms on this setting. Also, is there a way to set a property to limit what value the knob can output? For instance flip a switch and have properties in a case structure that would say "This can only output 100 ns to 500 ns".
Thanks.
Message 1 of 10
(6,119 Views)
I don't see a setting for that. I like to use an event structure, and that way you could filter out the events that you don't want (i.e. increment back to beginning).
Message 2 of 10
(6,098 Views)
Plese attach an actual VI instead of a picture.
What is a "knob ring cell"?
You can define data entry limits for knobs and you can also prevent jumps.
Message 3 of 10
(6,081 Views)
I'm fairly certain that's an enum control.  Might be a listbox.
If your version of LabVIEW is recent enough then there should be a property node called "DisabledItems[]" that you can pass an array of indexes to.  Whichever indexes you pass to it won't be selectable from the enum list any more on that particular control.  You could use that to exclude selections not currently supported.
Message 4 of 10
(6,065 Views)
In the simple .VI below I would like to prevent jumping from 100 ns to 10 ms (going all the way around) when using the incriments on the digital display (what I called the ring cell before). In the case structure I would like to be able define a property such that the value could only be 0-2 (100 ns to 500 ns).
I didn't see any properties that would control this.
Thank you.
Message 5 of 10
(6,060 Views)
You could use In Range & Coerce to limit the range that you write to your indicator.  For the control, just set the Max and Min properties.
Message 6 of 10
(6,026 Views)
However, if you use the increment/decrement buttons, it will still wrap to the min once you try to go above the current max etc.
I would just hide the increment/decrement buttons and let the user chose exclusively by clicking on it.
Message 7 of 10
(5,983 Views)
I set the max and min properties I can about so that using the incrimentor doesn't allow for certain values. I don't see an option for disallowing jumps however. I would like to keep the increment buttons visible because they are quite useful, but if that is the only way to prevent jumping then so be it.
Message 8 of 10
(5,961 Views)
Perhaps you should hide the buttons and then create your own buttons that don't loop around at the end of the list.  Maybe disable and grey out the button in question when it is at one extreme or the other.
Message 9 of 10
(5,936 Views)
In the Value change event for the control, check old and new value, if it goes from last to first or the other way around discard it/set it to end value.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 10 of 10
(5,879 Views)
