Automatically generate color
change hue value in FOR means?
What i want is actually when i run the VI each time different colors should come depending on the number of parameters.
So It will be the same as in Freelance_LV 's VI to create a random number values for hue?
Nghtcwrlr
Message 11 of 17
(1,248 Views)
I would use the loop iterator output to change hue. So you will get a "rainbow" color table!
(Note: Your HSL2RGB.vi is part of a lvlib, so I can't run it due to missing lvlib file...)
Message 12 of 17
(1,247 Views)
Hello Gerd.
See attached for the lib file.
I tried as u said. But i am getting only one color as output.
Nghtcwrlr
Message 13 of 17
(1,232 Views)
Hi Nghtcrwlr,
you're really not able to calc a HUE value from the loop iterator?
It's just a simple multiplication...
Message 14 of 17
(1,230 Views)
Hello Gerd
I did the same multiplication like u did. But used another constant value instead of 2Pi.
And what i get as output is : ( See Attachment)
Just first color and then the rest is all white.
Nghtcwrlr
Message 15 of 17
(1,216 Views)
Hi Nghtcrwlr,
you really should read the context help of that "HSL to RGB" VI.
It clearly says "Warning! Hue is in radians!"...
What do you think why I was using "2pi" for scaling the HUE value?
Message 16 of 17
(1,214 Views)
opps... i didnt see that one.Smiley Happy Thanks
Nghtcwrlr
Message 17 of 17
(1,196 Views)
