How to write an image in the XML file
Hi all,
I need to save image files along with some data in the xml file.
is it possible?
can you please give me suggestion.
(5,189 Views)
Hi!
Try giving a look to this article:
http://www.xml.com/pub/a/98/07/binary/binary.html
It's not strictly about Labview but it's interesting.
Marco
(5,175 Views)
Another link (Labview Base64 encoding/deconding vi's):
https://decibel.ni.com/content/docs/DOC-5544
So I think what you should do is
1) flatten your binary object to string
2) Encode
3) Place the encoded string in yur xml
When reading do the opposite:
1) Read xml Base64 string
2) Decode
3) Unflatten
Let me know if it works,
regards,
Marco
(5,173 Views)
Or If Labview schema is acceptable, it is fairly straight forward.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(5,158 Views)
