Automation
I do experiment on semiconductor devices.
I have a KEITHLEY 2635B to apply voltage and
measure current across a semiconductor device.
The start voltage is -0.1 V; The end voltage is 0.1 V;
The step voltage is 0.002 V. The current limit is 0.1 mA.
The delay time is 0.05 s.
I use a Lake Shore Model 330 as a temperature controller
for a helium refrigerator.
The starting temperature is 298 K; The ending temperature is 300 K;
The step temperature is 10 K.
The number of data is 100. The number of readings to average
is 4.
The both instruments are connected to a computer through a GPIB.
How can be a LabView block diagram to automate both voltage and
temperature instruments and acquire voltage and current
data on a Excel file by using a user interface (shown in red) please?
I know that this is really a difficult problem. I can't resolve it.
Thank you so much. I appreciate you.
Message 1 of 15
(8,808 Views)
This sounds a lot like you're trying to get us to do your job or your homework for you.
You'll need to write enough code to get to a more specific question and then post again, or start by doing some tutorials or watching some videos and trying it again.
Message 2 of 15
(8,789 Views)
Hello. I posted a code for that, but it didn't appear in the site.
I post it again here. Voltage is on the x-axis and current on the y-axis.
Message 3 of 15
(8,759 Views)
If you are trying to do this yourself, you need (a) to learn LabVIEW (take a class, preferably one where you Get a Grade or Pay Money, something to force you to pay attention, do the work, and ask your instructor for help with concepts you don't understand), (b) find a LabVIEW "guru" and apprentice yourself to her (or him) for a few weeks to get "up to speed" quickly, or else (c) hire a LabVIEW Developer and let them do this.
If you are doing this "on your own", spend a bit more time on the LabVIEW Tutorials, make a serious effort, and come back with a specific question that doesn't sound like "Do my Homework for me".
Bob Schor
Message 4 of 15
(8,735 Views)
You're in luck, there are LabVIEW drivers and examples pre-made for everything you are looking for.  You will need to integrate them but for that you will need to learn a bit more about LabVIEW.  It should not be that hard however.
Drivers..
Lakeshore - http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=2168
Keithley - https://www.tek.com/source-measure-units/2635-software/keithley-series-2600-2600a-2600b-native-labvi...
Message 5 of 15
(8,725 Views)
Hello. When I click on the file IV_T_2602A.vi, an error occurs as attachment shows.
How can I fix the error while I use LabView 2018 please? Can Lakeshore 340 be replaced with Lakeshore 330? Is there a way to change the big blue coordinates such as x-axis to be voltage and y-axis to be current please? Thank you so much.
Message 6 of 15
(8,604 Views)
Hello. I found a program in the attachment that I think can resolve the problem. However, when I run it, there is an error 7 as shown in the png file below.
How can I fix the error please?
How can I replace Lakeshore 340 in the program with Lakeshore 330?
Is there a way to change the big blue coordinates in the front panel of the
program such as x-axis to be voltage and y-axis to be current please?
Thank you.
https://forums.ni.com/ni/attachments/ni/170/843298/1/IV_T_2602A.vi
Message 7 of 15
(8,656 Views)
Hi Farzad,
By checking (aka debugging) which file is missing (or in the wrong location)…
Your image is missing the file path control: which path did you choose?
Btw. that VI is a horrible example with lots of outdated functions - and RubeGoldberg constructs all over. Especially the file path generation in the upper sequence frame (in frame 0) is bad…
When you want to replace hardware you need to read the specs of both devices. Only replace one by the other when the specs for your desired measurement/application is the same…
Yes.
Message 8 of 15
(8,594 Views)
Hello. I could solve the two problems:
1) To fix the "error 7", open a folder called "Sirshendu" in your D drive, and put a notepad file called "data" inside the folder. The funny name Sirshendu is in the original front panel.
Then, run the program and the error goes away.
2) Below the big coordinates in the program, there is a user interface for Y-axis that you can change it to current and even choose a log. scale.
3) I can't change the Lake shore 340 to Lake shore 330 in the program. However, maybe this program works for Lake shore 330 too. My KEITHLEY is 2635B but any program for 2602A works for 2635B as the company says.
Thus, I should run the program in the lab with real equipment to see whether the program works in the lab or not.
I post two png files after setting up the program at home for my future real experiment.
I'll be back to report the real test.
Message 9 of 15
(8,621 Views)
Can you please replace Lake Shore 340 with Lake  Shore 330 in the Block Diagram
of the LabView program of the link below and give a new link:
 You may give me the instructions for the replacement please.
The program doesn't work with Lake Shore 330, and my instrument is Lake shore 330.
I appreciate you.
Message 10 of 15
(8,580 Views)
