Automation
Hi Farzad,
The program doesn't work with Lake Shore 330, and my instrument is Lake shore 330.
So what is the problem? What exactly "doesn't work"?
What have you tried so far?
Did you debug the VI?
You may give me the instructions for the replacement please.
Several suggestions:
  • That VI is using old GPIB functions, replace them with VISA functions.
  • That VI is missing error handling, so implement that too (after replacing GPIB functions by VISA counterparts).
  • Check the GPIB address used for the device.
  • Check the cabling.
  • Then read the (programming) manual of your device and check/probe all (!) commands send to your device. Are they supported in the same way as is done by the Lakeshore340?
  • That VI is also communicating with a "SM2602" device: do you also use this one? If not: remove the communication with that device…
  • As that VI is generally in a very bad shape it might be a good idea to create a new VI from scratch: Did you look for a device driver specifically for your device?
Message 11 of 15
(3,231 Views)
I used the link below to run a Keithley 2635B and Lake Shore 330 at the same time,
because I need "current vs. voltage at different temperatures" for a semiconductor device.
Both Keithley 2635B and Lake Shore 330 are connected to a computer through a GPIB in my lab.
https://forums.ni.com/ni/attachments/ni/170/843298/1/IV_T_2602A.vi
The link is a LabView program. The program runs the Keithley 2635B, but it can't run the
Lake Shore 330 for having different temperatures. The reason is that the program was built for Lake Shore 340 in the past. If you please watch the Block Diagram of the program in the
link above, you can see a "Lakeshore 340" at the heart of the Block Diagram.
Thus, if someone can replace it with "Lakeshore 330", then the program will work for the experiment. However, I don't know how to replace it. I put a png file here to show what should be changed at the heart of the Block Diagram as I explained.
I appreciate you.
Message 12 of 15
(3,220 Views)
Lakeshore 340 in the middle of that just happens to be the name given to a terminal, and that is the local variable of it.  You could change the name of the control to "gobbledy-gook" and the VI would function the same.  So "replacing" it with "Lakeshore 330" vs. "Lakeshore 340".
Follow the advice given to you for cleaning up this VI, or the better advice of starting over from scratch.  If that is beyond your level of LabVIEW experience, you may want to look at hiring a LabVIEW consultant to do it for you.
Message 13 of 15
(3,218 Views)
I did a real test in the lab. I used the link below to run a Keithley 2635B and Lake Shore 330 at the same time in the lab, because I need "current vs. voltage at different temperatures" for a semiconductor device. Both Keithley 2635B and Lake Shore 330 are connected to a computer through a GPIB in my lab.
Thus, if someone can replace it with "Lakeshore 330", then the program will work for the experiment. However, I don't know how to replace it. I put a png file here to show what should be changed at the heart of the Block Diagram as I explained. Please Help me.
I appreciate you.
Message 14 of 15
(3,217 Views)
Instead of continuing here in this old and long thread.  Stick with the newer thread that you created here.
https://forums.ni.com/t5/LabVIEW/Automation/m-p/3839559#M1086462
Message 15 of 15
(3,214 Views)
