06-25-2024 03:25 AM
Hello, I have been analyzing some CAN ID, and I found one that has a CRC8 acording to my dbc. The last byte is the CRC8, but I don't know how is calculated. The first byte (byte 0) is a CHK which is The XOR of the rest of bytes + 134. 134 is the ID. I would like to find out what is the formula for the CRC.
The message of the dbc is:
F r MLB:
'Berechnung siehe Lastenheft 'Kommunikationsabsicherung f r FlexRay und CAN''
Ab MQB und MLBevo:
'Berechnung siehe Lastenheft 'End-to-End Kommunikationsabsicherung'
Endwerte siehe Begleitdokument 'S-PDU Kennungsfolgen
which means:
For MLB:
'Calculation see specification 'Communication security for FlexRay and CAN''
From MQB and MLBevo:
'Calculation see specification 'End-to-End communication security'
End values see accompanying document 'S-PDU identification sequences
| 238 | 34 | 37 | 32 | 0 | 107 | 252 | 216 |
| 99 | 35 | 37 | 32 | 0 | 99 | 252 | 92 |
| 126 | 36 | 37 | 32 | 0 | 123 | 252 | 94 |
| 243 | 37 | 37 | 32 | 0 | 115 | 252 | 218 |
| 75 | 38 | 37 | 32 | 0 | 107 | 252 | 121 |
| 198 | 39 | 37 | 32 | 0 | 99 | 252 | 253 |
| 190 | 40 | 37 | 32 | 0 | 123 | 252 | 146 |
| 51 | 41 | 37 | 32 | 0 | 115 | 252 | 22 |
| 139 | 42 | 37 | 32 | 0 | 107 | 252 | 181 |
| 6 | 43 | 37 | 32 | 0 | 99 | 252 | 49 |
| 27 | 44 | 37 | 32 | 0 | 123 | 252 | 51 |
| 150 | 45 | 37 | 32 | 0 | 115 | 252 | 183 |
| 46 | 46 | 37 | 32 | 0 | 107 | 252 | 20 |
| 163 | 47 | 37 | 32 | 0 | 99 | 252 | 144 |
| 219 | 32 | 37 | 32 | 0 | 123 | 252 | 255 |
| 86 | 33 | 37 | 32 | 0 | 115 | 252 | 123 |
06-25-2024 04:20 AM
Hi lab,
You write down the formula (XOR all bytes except first one and add 134) and then you ask for the formula in the next sentence???
06-25-2024 06:04 AM - edited 06-25-2024 06:04 AM
