Avarage calculation with labview
Just check the on-line help. Go to Help>Search the LabVIEW Help and find the 'Application Builder' topic.
Message 21 of 28
(1,757 Views)
Accepted by ago
have a look at this tutorial: it explains in detail how to create executables, installers... with Application Builder, for LabVIEW 8.x.
I hope it will help you!
Bye!
Licia
Message 22 of 28
(1,736 Views)
hi friends
now im almost finished with my program 🙂 the i will nomore torture you with my problems
but i have still a problem
my programm is finished (attached: PT100_Datenerfassung_6
and with the new bought application builder i created an application
but when i go with the now application on a new pc (with runtime engine) it doesnt work,,,, it says to me to search an dll file
can somebody help me???
Message 23 of 28
(1,712 Views)
sorry for the late reply.
In case you have not still been able to solve your problem, could you please provide a screenshot of the error message you got?
Thanks!
Licia
Message 24 of 28
(1,671 Views)
hello together thank you for the fantastic support 🙂
my program is finished and with the application builder i created a stand alone exe 🙂
but i have still questions....
my program should be conform with the GMPrules (medical use,,,Annex 11) .... for this I should buy the DSC (Datalogging and Supervisory Control )?
and
it is possible that labVIEW creates/records a legend with all the symbols/VI and maybe the explenation what they do? .... i need such a record for the validation of the program
Message 25 of 28
(1,593 Views)
Hi ago,
yes it's possible to read the icon images. Use an invoke node for it. If you insert a description for all your vi's, then you can read this for the documentation, use the property "VI description" for it. With the icon and the description you can create a report.
See also the report functions for VI documentation.
Mike
Message 26 of 28
(1,587 Views)
Hi mike
sorry but i dont really understand what to do with this invoke node:-) how can i wire all icons to one node?
i taged my actual programm
maybe you can see what my problem is 🙂
Message Edited by ago on 01-27-2009 07:48 AM
Message 27 of 28
(1,576 Views)
Hi ago,
see the attached picture. It shows how you can read the VI Icon. You can then write it to a file or draw it in a picture indicator. You can then use the stored picture to create for example a html report.
Hope it helps.
Mike
Message 28 of 28
(1,570 Views)
