Average Data
What I want:
I want to have a numeric control that controls the amount of data that will be averaged.
(ex: numeric control set to 10)
This control results in the 10 data points before and the 10 data points after the current iteration will be averaged
My guess at a solution:
The numeric control will be combined with the iteration in a for loop.
My array of data will enter this for loop and combine with this.
My output of the for loop will be the averaged data.
I will then delete the first 10 lines of the array but I can do that.
An example vi of this would be awesome, I figured it will take someone no time at all to implement this.
Thanks!
Christian
Message 1 of 20
(6,500 Views)
Hi cseymour,
this really sounds like homework. The usual reply for homework is:
Start to code on your own. Then attach what you have achieved so far and ask for specific problems of your code…
Message 2 of 20
(6,491 Views)
If only it was homework.....
It's for a senior project that I have been working on, I am novice to many aspects of LV since was just introduced to it a month ago.  Right now my mind is running in circles so that's why I need help. But I'll attach the subvi that I have that I will implement this in.
Long story short, I have IMU data that has already been saved to a tdms file. I am pulling the separate waveforms out and I simply want to cancel some noise out and smooth the data. I want to average it as I posted above.
The vi is really a mess right now so dont be shocked.
Thanks!
Christian
Message 3 of 20
(6,481 Views)
Hi cseymour,
have a look at PtByPt-Mean and try to use that on one of your waveforms…
Message 4 of 20
(6,476 Views)
Yes I have looked at it.
What it does is take your sample length and use the previous values to find the mean.
I want to use the previous and future values to find the mean.
Christian
Message 5 of 20
(6,469 Views)
How is the program supposed to predict the data from the future?
Message 6 of 20
(6,465 Views)
I have already collected all the data and now i am running it through post-processing.
Christian
Message 7 of 20
(6,458 Views)
OK, so this is a trivial problem. Can you attach some typical data?
Message 8 of 20
(6,451 Views)
File attached. Is that what you want?
Christian
Message 9 of 20
(6,440 Views)
No, don't flood us with tons of irrelevant data. Just attach the 1D array that contains the data. You also need to decide what to do with the data at the beginning and end, where the averaged subset is truncated.
Message 10 of 20
(6,435 Views)
