Average Sub Arrays
I'm trying to have a vi that receives an array from file, then constructs sub arrays (according to  FPS/Average Array Every), then takes the mean, finds the difference from each data point, and counts the number of times where the difference is larger than the threshold. Please review the attached file--my block diagram.
At this point, the vi is running but the is a bug in the code which I can't find :-(.
When I run it on some sample data counter returns~350 where it suppose to be only 3.
I'll appreciate if you can take a look at it.
Thank you,
P.S..
I'll be happy to upload the vi and a sample data file if needed.
(5,087 Views)
Accepted by simply_me
simply_me,
You take an array subset, get the mean that looks ok.  But then you figure out the difference between the mean and the entire array you started with instead of the subset you used to calculate the mean.  Am guessing you meant to do this.
(5,041 Views)
Thanks Wayne. C, it's working great now!
(5,013 Views)
how would i do an average of an array from
index 100 to 300?
if i have an array of 2000 indexes,
how can i get the average from 100-300?
in
excel it would be
=avg(C100:C300)
Krispiekream
(4,646 Views)
You should really start a new thread instead of adding to an old thread that is already marked as solved!)
Use array subset, then take the mean of the subset.
(4,628 Views)
haha. ok..i will do that next time.
i just thought i don't wanna borther more people..
i wanna make sure i search the forum for answers before i post my own post.
but thanks.
Krispiekream
(4,576 Views)
You ARE bothering more people by adding to an old thread, because some of the old participants might still subscribe to updates.
(4,566 Views)
