Average Value Scope
But you say, delay function have to be use ? How can ı use delay function in this vi ?
Message 41 of 46
(2,771 Views)
You aren't even bothering to take a free tutorial or to read the help or even have context help turned on.
Message 42 of 46
(2,766 Views)
I watch several pdf tutorial , white paper , webcast,  youtube tutorial https://www.youtube.com/watch?v=frLkFT0VPAY but ı can't handle it . Also ı read every function  help.
Message 43 of 46
(2,760 Views)
But you are unable to use quick drop or the Search button on the function palette to find the function called Delay? Is this a language problem? You aren't using the English version of LabVIEW?
A list of tutorials can be found at https://decibel.ni.com/content/docs/DOC-40451
Message 44 of 46
(2,753 Views)
Also ı used time delay func. but it still seems something wrong ?
Message 45 of 46
(2,746 Views)
You've got it in the wrong place. Place it before the read and after you configure the number of averages. See if makes a difference.
Message 46 of 46
(2,736 Views)
