Average of Cycle Periodic Signal
Hello!
I am reading, from DAQ USB-6009, a periodic signal. Lets imagine that the signal is a periodic triangular wave that I have on an array of N*X elements, in which N is the number of cycles of the wave, X the number of elements of each cycle.
My idea now is to average all this periodic waves!
I want to pic the first value (index=0) of each periodic wave, that is, pic the element 0, 0+X, 0+2X, 0+3X...until 0+NX and calculate the average of this group.
Then I want to do the same for each point of the wave (index=1, 2, 3...X)!
The final result is just one cycle with the same period and the same number of elements (X), but that is the average of all waves!
How can I do this automatic?
Thanks for your answers
Alexandre Ferreira da Silva
(3,072 Views)
There are many ways to do this... here is one, maybe not the best, but quite easy, assuming you know the number of point in a period... Smiley Surprised
1. count how many "entire period" you have in the array
2. extract (in a loop) values from 0 to N-1, then from N-1 to.... and so on
3. build an 2D array of periods
Then you can extract a line to calcute what ever you want on each period or get a column to average all the K-th values.
Hope this helps
Message Edité par TiTou le 11-22-2006 01:07 PM
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,063 Views)
