Averaging Vectors
Are there functions that input a vector, break it down to it's component vectors and back again?? My application involves averaging wind speed and direction. I want to average 60 one second wind vectors by averaging the components and then converting the averaged components back to a single vector of wind speed and direction. Thanks in advance for the help.
ssmith@bnl.gov
Message 1 of 20
(5,653 Views)
Am I understanding your question correctly:
You want to resolve a vector into an x-component and a y-component.
You want to average all the x's, and all the y's, then build them back into a vector?
Cory K
Message 2 of 20
(5,650 Views)
maybe something like this?
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 3 of 20
(5,646 Views)
You need first to decide about the repesentation of you vectors. You could make a cluster of the componente, or and array where by index 0 will be the first component, index 1 the second component and so on, or if you stick to 2D you could use complex numbers for the vector representation.
Please find attach an example for averaging 3D-vectors based on the first method a cluster of the components.
Message 4 of 20
(5,623 Views)
Cory--
            That is exactly what I want to do.
S
Message 5 of 20
(5,619 Views)
I would recommend to combine the two arrays into a complex (CDB) 1D array. The averaged vector is simply Sum/N.
Message 6 of 20
(5,607 Views)
First the single vector must be broken down into it's component vectors and then averaged.
Message 7 of 20
(5,550 Views)
Hi Christian,
I recently had to do some averaging of vectors in three-space and resorted to using complex to do this. As I was doing my code I was thinking "how would Christian have done this?".
Do you have Nuggets of wisdom you could share regarding vectors with more tahn two components.
Curious,
Ben
Message 8 of 20
(5,547 Views)
You can input a vector into this complex array and vector avaeraging will be done correctly??
Message 9 of 20
(5,541 Views)
do you think LabView will calc an average incorrectly?? Smiley Wink
For real:
Many (most basic) functions are polymorph an can take (nearly) any kind of data...
Message 10 of 20
(5,516 Views)
