Averaging Vectors
What I need is specific VI names not general info, if there are any. Or do I have to, using math trig VIs, do the vector math one step at a time??
ssmith
Message 11 of 20
(1,705 Views)
Are your vectors in 2D or 3D? What is your LabVIEW version?
Message Edited by altenbach on 08-17-2009 11:03 AM
Message 12 of 20
(1,697 Views)
Here is a Snippet.
 I take two 1-d arrays of doubles that have the U and V vector components. I convert to complex find the total and divide by the number of components. then I divide to find the average and then convert the complex back to polar to get the Uavg and Vavg values.
I think this will do 3d but I have not thought about to hard or tested either.
Ben
Message Edited by Ben on 08-17-2009 01:12 PM
Message 13 of 20
(1,693 Views)
I have version 8.6. The vector is wind speed and wind direction. It has not yet been resolve into it's u and v components. This is the first part of the problem. Then averaging the u and v components is the middle. The last part, and again difficult part is merging the u and v  components back into a speed and direction vector.
ssmith
Message 14 of 20
(1,677 Views)
But Ben!
Those look rubes. Why not just average each vector seperately?
Good point. Lets just call those two VIs a test to see if Ican create a snippet.
Ben
Message 15 of 20
(1,676 Views)
Wind speed is "r" and the direction is theta.
The example above is the answer to your question turned inside out.
Ben
Message 16 of 20
(1,673 Views)
Correct! Once the single vector is resolved into it's components each component is averaged. Then you take the average of the u and v and then then construct back to a single vector.
ssmith
Message 17 of 20
(1,672 Views)
ssmith
Aggreed.
Ben
Message 18 of 20
(1,669 Views)
If you are starting with magnitude and direction, why not use Polar to Complex, use Ben's code to average, then Complex to Polar to return average magnitude and direction.
Message 19 of 20
(1,654 Views)
Because until now I didn't have the info you just gave me! (The name of the vi) LOL! Thanks alot. I'll try it and let you know.
ssmith
Message 20 of 20
(1,647 Views)
