Averaging in intervals
My main Program operation is to turn on a heater for a specified time (10 s), and put it off for 60 sec. Data between 30s-50s is averaged. This is repeated for a required number of cycles. The top loop tells the heater when to switch on and off ( not included completely), and tells the bottom loop when to start averaging. The bottom loop cannot have a outer while loop, and the random number function cannot be placed inside a new while loop. Currently I get a average of the data after all cycles. Would anyone be able to suggest me in a direction where I could get the average for each individual cycle.
(3,771 Views)
1. You really should turn your top loop into a State Machine.
2. Your FGV would be more efficient as a Global Variable
3. You might want to have a look at the Mean PtByPt.vi for keeping your average.
4. You might also have a look at the Boolean Crossint PtByPt.vi for telling the Mean PtByPt.vi when to reset.
(3,750 Views)
Thanks, using the PtByPt vi's hepled. However, I'm still off my average as the data when the boolean turns off is added as well. Is there any way I could exclude that data point? I have incuded getting the average by using shift registers and can be run for a single cycle for comparison.
(3,706 Views)
Accepted by prithvibasak
See if this helps some...
(3,686 Views)
