Avoid Tree control expanding when written to?
I'm using a tree control to display results from a database search among several tables, where each table is named in Indent level 0 in tree, and the search results at level 1. When I do the search, the tree is expanded automatically, which gets rather big because of hundreds of lines at level 1, and I want to expand each Item at my own will. Now I need to scroll down and close level 1 manually before doing that. I wonder if there is a property/setting to NOT expand indent levels when a Tree is written to? I've tried Active Item->Open? property to False, but it is still expanded. Is there a way to fix this issue?
Regards
Bård B
(2,468 Views)
Accepted by BBend
Use an invoke node.  You can either use the "Open/Close:Item" method after adding each item, or you can use the "Open/Close:All" after the tree is filled.
(2,433 Views)
I also suggest calling the Defer Panel Updates property of the Panel class before/after every tree update, it will make your UI more responsive.
(2,416 Views)
That did the trick!
Thanks for the help, guys!
(2,367 Views)
What specifically did the trick?  Defer front panel updates, or the suggestion about the Close item?
(2,357 Views)
